Offroad & 4x4
please help
Old Jul 30, 2004 | 08:40 PM
BondoFord's Avatar
BondoFord
please help
wut can i do to stop my tires from looking like this/ \
Old Jul 30, 2004 | 08:42 PM
fishmanndotcom's Avatar
fishmanndotcom
take it to an alignment shop!
read this http://www.ozebiz.com.au/racetech/theory/align.html
-cutts-
Old Jul 30, 2004 | 08:51 PM
BondoFord's Avatar
BondoFord
an alingment didnt help
Old Jul 30, 2004 | 08:53 PM
JeremyH's Avatar
JeremyH
Then they didnt do it properly. Have them set the camber and caster as well.
Old Jul 30, 2004 | 08:56 PM
BondoFord's Avatar
BondoFord
they tilt in from the top not front or bak
Old Jul 30, 2004 | 08:58 PM
Racerguy's Avatar
Racerguy
What year and model of truck do you have?
And welcome to the forum
Old Jul 30, 2004 | 09:00 PM
BondoFord's Avatar
BondoFord
a 1991 extracablongbed f-250 larieat 4x4
Old Jul 30, 2004 | 09:48 PM
MustangGT221's Avatar
MustangGT221
That is adjusted by the camber adjustment nuts (located where the balljoint is mounted). The stock adjustment nut is for 1 degree positive or negative, they have 2 and 3 degree bushings. You either need a new bushing or you're suspension is off somehow. Did you lift it? Do you have the correct axle pivot drop brackets?
Old Jul 30, 2004 | 10:03 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
GET AN ADD-A-LEAF for the front...your springs are sagging.
Old Jul 31, 2004 | 01:40 AM
Racerguy's Avatar
Racerguy
Yeah what cleatus said
Or you can get a set of diesel springs.
With the way the front end geometry works on these trucks when the springs sag you get lots of negative camber.
Old Jul 31, 2004 | 07:29 AM
JeremyH's Avatar
JeremyH
Ok....you need to have the camber set.
Read the link that fishmanndotcom provided.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
