CB radio hookup
no, you will not burn it up. if the ant. is not tuned right(swr) you will not get as good of range. one thing that can burn it up is keying the mike(trying to transmit) with no ant hooked up to the unit
So if I dont have an ant hooked up then dont try and talk on it correct. Just wanna make sure I get this cause I dont wanna mess it up even tho it was only 3 bucks lol.
So how do you tune it?
You need an SWR meter to tune it right. I would recommend taking it to a CB shop and having them do it. They only charge about $20 around here. Most decent truck stops will have a CB shop nearby if not on the property itself. You don't need to have this done to use the Cb though, just don't use it unless you have an antenna hooked up.
Chris
Chris
Boo_Daddy
Mar 30, 2009 12:23 PM
FreeDevin
Mar 29, 2009 11:36 PM
