speed chip
Old Jul 29, 2004 | 08:50 AM
Boyle067's Avatar
Boyle067
Question speed chip
does anyone know if those cheap $2.00 ECU speed chips made for explorers actually add horspower? Also anyone know if they are bad in anyway for example lower mpg? Thanks.
Old Jul 29, 2004 | 03:29 PM
CobraXP's Avatar
CobraXP
I don't know what a $2.00 ECU chip is - but if you are referring to the things you see on ebay - don't waste your money or time.
As far as a chip goes - the only ones I would recommend are Diablo and Superchips.
Old Aug 12, 2004 | 08:31 PM
performancenut's Avatar
performancenut
E-bay specials: they place a cheap (less than one dollar) resistor in place of the intake air temperature sensor and "trick" the PCM into placing a richer fuel mixture into the chambers- thus allowing for some increased power. Long term use results in excessive engine wear, clogged catalytic converters, and poor fuel economy.
Don't waste your money!
Old Nov 11, 2004 | 06:36 PM
DouginTahoe's Avatar
DouginTahoe
umm what company makes that chip ?
Originally Posted by Got-X
I would reccomend going with an @PT3N Chip, they offer superior tuning to all the other chips on the market becuase they write their own code instead of using off the shelf programing....
Much better gains....
just reading through your post... what is @pt3n ? I cannot find on any search.
thanks,
D
Old Nov 11, 2004 | 06:54 PM
CobraXP's Avatar
CobraXP
a p t e n chips.
They used to be a good company to go through to get chips, but since their prime employee/programmer left, its not as good as it used to be. If you are looking for a chip, I would recommend checking with one of this site's sponsors: www.motorhaven.com
You will get a great chip or tuner through them.
fumminsplease
May 11, 2010 06:45 AM
tcongo
Jan 7, 2005 10:15 AM
shawn001
Computer Chips & Tuners
Aug 12, 2004 09:50 AM
cat-alac
Feb 11, 2004 10:03 AM
chamill
May 22, 2003 08:28 PM
