clutch problem
Old Jul 29, 2004 | 02:00 AM
4x4man514's Avatar
4x4man514
clutch problem
hey guys,
i have a 89 f350with a 5 speed in it.i have to try to push the clutch THROUGH the floor to shift gears.the truck also will not start without jumping the solenoid out.several people have told me the clutch needed replacing.
heres the deal,i had a 93 250 with the same problem and it turned out to be worn bushings in the clutch pedal assembly.
in the 89' i cant see if the bushings are wore or what.is this a common problem on all hvy duty trucks because of the powerful pressure plates?
has anyone had similar problems with similar years?thanks,Kevin.
Old Jul 29, 2004 | 11:45 AM
gbeach's Avatar
gbeach
i had same problem with 93 f250 and thought immed. it was my clutch. but the plastic bushing had broke and was gone at the linkage where pedal joins linkage and hence i had metal on metal which had worn from a round hole to a eggshaped. so i was getting a lot of play before i felt any pressure. had also worn the master cylinder rod hole. check where these join. its easy fix
