check engine
Old Jul 28, 2004 | 08:00 PM
robertleeii's Avatar
robertleeii
check engine
i have a 2001 psd and sometimes when i am passing cars my check engine comes on but then it goes away a few miles down the road. oil and everything else kept uptodate. what is going on?
Old Jul 29, 2004 | 08:42 AM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Do you mean the SES (service engine soon) light?
When the SES is triggered under the circumstances you mentioned it is normally from overboost, or ICP out of range if you have a chip or tuner installed. If you do not have a power adder I would suspect a faulty exhaust backpressure sensor, or a plugged EBS tube (also possible with a chip).
The easiest way to narrow it down would be to take it to autozone or somewhere and have the codes pulled.
