i am planning to do a bunch of mods to a 400 i have in a 73 torino. i was just wondering what kind of gas milage any of you all have after putting on performance enhancers.
A built 351C in my old Mach 1 (Holley 600, #69 primary jets, Edelbrock Performer, 10.2:1, "3/4" cam- 294* duration, .564 int., .536 exh., Hooker Super-Comp headers) was good for 11 MPG, on the freeway, at 60 MPH.
When you play, you pay.
Good luck, and it's nice to see a 400 as a choice for power. My dad had a 72 Mercury Montery with a 400 in it. It was a strong running engine, for a stock motor in such a big car.
I just had my 400 heavily rebuilt, had a new milder cam installed, bored it over .060, thats what i wanted, hopefully i wont hear from anyone youre not supposed to do that, i did it, and i have no problems, temp never gets above 160ish during highway driving, delbrock from the manifold up, and had the heads re done, also corrected the timing using a pre retarded timing timing set..im in the process of breaking it in, but it has all the power you could want, low and top end, i get better RPM range, ive had it up to 5000 while doing the 1/4 mile with it, and im getting 11 MPG right now...ohh, and i live at 9,118 ft above sea level...i dont know the number, but after a point, you dont need to know a number, you just need to know if its what you want or not..Hope this helped somehow....
---JOHN
There are several lighter modifications that will increase some horse power. A K&N air filter lets the carb suck straight down instead of at a 90 degree. They claim to add up to 5 hp. Dual Exaust also gives more power depending on your manifolds. I really noticed performance when I changed the springs in my distributor. It is just stock. The range the advance cover is greater. I beleive yours will have points. They make a weight curve kit I think for the ford points distributor. Headers will help. Don't try to run to big of tires. Little things like that all help.
To change the compression ratio of an engine you need to change the heads or pistons or both. You can also mill the heads or deck the block.
The easiest of these is to change the heads to a set with a smaller combustion chamber. If you are rebuilding the engine, a new set of flattop pistons is an economical way of increasing the CR.
You can get a set of Aussie Heads on Ebay. They are 58cc combustion chamber heads, but they will raise the CR of a stock 400 to 10.0:1. You will have problems with detonation with 93 Octane or less fuel. You should change the cam to a cam with a later Intake Valve Closing angle to reduce the compression.
Well I am using this truck as a weekend toy. mudding, offroad, towing, you know just put it to work. I have a stage 2 cam in it now and have a edelbrock intake with a holley four barrel
