Replacing mirrors
Old Jul 28, 2004 | 12:09 PM
GRB1's Avatar
GRB1
Replacing mirrors
Hello,
I was wondering how difficult it is to replace a mirror on a 03 Expy, driver side. I need to replace the whole unit. A Bus tried to wipe the mirror of as my Expy was parked on a city street!! Luckily the only thing that was hit was the mirror.
I have power/heated mirrors.
Greg
Old Jul 28, 2004 | 12:13 PM
Bikeitswift's Avatar
Bikeitswift
Mine pop apart
On my 97, they "pop" apart. There are four pieces altogether. The main assembly pops up of a spring-loaded stem, the glass part and its backing pop away from the motor plate, which unscrews so you can pop off the colored part tabs.
Old Jul 28, 2004 | 07:00 PM
HomerWinzlow's Avatar
HomerWinzlow
Remove door panel, remove 4 mounting nuts, disconnect electrical connector, replace mirror assembly.
Old Jul 28, 2004 | 07:34 PM
GRB1's Avatar
GRB1
Thanks for the quick replies,
Do the door panels just pop off or is a special tool needed? Any advice for removing the door panels would be appreciated.
Greg
Old Jul 28, 2004 | 07:41 PM
HomerWinzlow
Front Door Trim Panel —Expedition
Removal and Installation
Remove the door handle bezel.
Use service notch.
Remove the window control switch plate.
Use service notch and disconnect the electrical connectors.
Remove the two bolts and three screws, and remove the door trim panel.
CAUTION: To avoid damage to the door trim panel, lift the door trim panel by pulling directly upward on the armrest to disengage the panel clips.
To install, reverse the removal procedure.
Old Jul 28, 2004 | 07:48 PM
GRB1's Avatar
GRB1
Homer,
Thanks for the quick reply and the instructions!!
Greg
Old Jul 28, 2004 | 07:51 PM
HomerWinzlow
When removing the four retaining nuts on the mirror be carefull not to drop them down in the door.. you may never get them back.
jprix
Nov 21, 2016 01:15 PM
Lubbockguy1979
Sep 30, 2016 09:09 AM
t_lcohen
Mar 6, 2007 04:49 PM
adsacu
Jan 20, 2005 08:20 PM
97expy5_4
May 27, 2003 08:01 PM
