Timing Light not Flashing
Old Jul 28, 2004 | 10:23 AM
FilmGuy's Avatar
FilmGuy
My 91 5.0 always started right up, and although it idled rough it never had trouble starting. The other day I went to start it, and it just cranked and cranked... I replaced the plug, cap, rotor, wires.. started right up the first time, but then had trouble after that.
I put my inductive timing light on one of the wires... and nothing! Maybe a couple if weak initial flashes, but then none at all. I tested the timing light on three other vehicles I have around here, and it worked on all of them. Curious, I clamped it over the main lead going into the center of the cap, and did in fact get a continuous bunch of flashes, like I would expect.
I am wondering if maybe my coil is dying, and putting out a weak spark? The wires I put on are Bosch Premium, which I know are the spiral type, I don't know if that would affect anything...
Has anyone experienced this before? Any help before I go out and possibly waste $50 on a new coil would be mucho appreciated!
Old Jul 29, 2004 | 04:20 AM
missouguy's Avatar
missouguy
That would be my guess. Why not grab one from a salvage yard and give that a try before you put out the big bucks for a new one.
Frank
Old Jul 29, 2004 | 10:02 AM
wojo1989's Avatar
wojo1989
I just had this problem with my 92. I pulled the spout connector and hooked up the timing light and then had intermiten flashes but nothing consitent. I did have some spare lengths of Taylor wire laying around and made a new coil wire but I did that after I got sick of trying to mess with the timing so I dont know if it helped.
Steve
Acidic
22
Feb 21, 2014 12:10 AM
nvrsatisfied84
Aug 26, 2010 02:15 PM
regarrr
1978 - 1996 Big Bronco
Nov 7, 2008 09:09 PM
mxhowes1
Mar 3, 2008 10:05 PM
77sc
Electrical Systems/Wiring
Jan 23, 2002 01:16 AM
