Firewall flexing
Old Jul 28, 2004 | 10:22 AM
kevan b's Avatar
kevan b
Firewall flexing
On my 1988 F150 the firewall flexes when I push in the clutch pedal, I noticed the sheet metal on the firewall seems to be separating at a seam. Is there a fix for this and how hard is it. Also at the same time the clutch safety switch is not working, could this firewall flex be causing the problem with the switch?
Thanks
Kevan
Old Jul 28, 2004 | 12:52 PM
Sryaxalot's Avatar
Sryaxalot
Talking
I had the same problem on my 88. My firewall was seperating when the pedal was pressed. I had a buddy put a small weld on it, it helped alot, it should help the clutch switch problem as well, but I had mine bypassed long before I fixed the firewall, my clutch was hard enough to push, and I literally had to put it to the floor to get it started. I'm not sure how to bypass the switch, but I was lucky enough to find a mechanic that did it for $15 bucks, I hate working with wiring. Oh and if you do get the firewall welded, make sure to unhook your battery. I heard it can cause problems and I didn't and it corroded some of my wires. Not exactly sure if the welding caused it, but when I parked it, no problem, after the welding, I tried to start it, and had to rewire some components, so thats just a little "Beware" or just in case. Hope this helps.
Old Jul 28, 2004 | 12:59 PM
andym's Avatar
andym
Ford sells a firewall reinforcement kit for your truck for about $20.
Old Jul 28, 2004 | 01:11 PM
Sryaxalot's Avatar
Sryaxalot
Sounds a lot easier, safer and cheaper than my method, wish I knew that when I had the problem Oh well, you always gotta ghetto rig somethin right?
Old Jul 28, 2004 | 01:22 PM
kevan b's Avatar
kevan b
Thanks, both of you, called the dealer and you can get the small kit for about $6.00 bucks now. it sounds like it reinforces the firewall behind the clutch cylinder. My firewall has not shown any cracking or damage around the master cylinders, but the seam around the top of this section is separating away from the rest of the firewall, does not sound like the kit will fix that I may have to make a reinforcing strap myself or have the neighbor weld it.
Again thanks to both of you..
Old Aug 21, 2004 | 05:31 PM
Katmandu's Avatar
Katmandu
Anyone know the Part # for this Kit ??
Old Aug 22, 2004 | 08:41 PM
tmrider's Avatar
tmrider
Dont know about the # but I have a 87 F250 and had the same problem and drilled a 3/8 inch hole a couple inches to the right and put a body bolt with nut.It brought the clutch pedal way up,a little bit past the brake pedal.It also helped the safety switch which I did bypass.There`s a switch located on the clutch pedal assy. under the dash.I took the plugin off and put a fuse in the plugin and elect. taped it.Later I`ll cut it and wire nut it.Tony
Old Aug 22, 2004 | 09:42 PM
Katmandu's Avatar
Katmandu
Thumbs up
Originally Posted by tmrider
Dont know about the #.....
I found them. Copied these from another thread.
E3TZ-7K509-A small kit.
E3TZ-7K509-B Big Kit
the small kit consist of::
template for drilling correct holes.
4 bolts and nuts.
instruction sheet.
re-inforcement bracket.
large kit consist of::
instruction sheet.
large re-inforcment bracket.
hardware kits.
Anyone have pics of the re-inforcement brackets in these kits ??
Old Aug 22, 2004 | 09:54 PM
tmrider's Avatar
tmrider
4 bolts and nuts.
instruction sheet.
instruction sheet.
Thanks for the info.Is the kit from the dealer or is it aftermarket because I don`t know how long my rig job will last.Tony
Old Aug 24, 2004 | 01:35 AM
Katmandu's Avatar
Katmandu
Arrow
From the local Ford Stealer.
Old Aug 24, 2004 | 08:18 PM
tmrider's Avatar
tmrider
Thanks,But i`ll make one at work.Tony
Old Aug 27, 2004 | 08:49 PM
Katmandu's Avatar
Katmandu
Arrow
Can you post pics of it when you are done ??
Anyone else have pics of their bracket and repair job ??
