$1000 for more power?
Old Jul 25, 2004 | 08:51 PM
jjjou812's Avatar
jjjou812
Smile
Hi. I have 99 f150 supercab 4.2 5sp 4x2 3.08gears 52,000 miles. Great truck. But needs more power. In Sept. I'll be loading up and driving from NY to AZ. Last time I drove cross country the truck got the job done, but more power would make for easier cruising on the open road and mountain climbing. The long lists of possible upgrades here are useless to me. Can someone please tell me what I should do for under $1000 to get a noticeable improvement? If $1000 is not enough to make a real difference, please tell me and I'll be content with what I have. Thanx.
Old Jul 27, 2004 | 11:33 PM
homer4.2's Avatar
homer4.2
I really don't think you will find much more under 1000 dollars that will give you an extreme amount of power. You could find a used supercharger that would greatly benefit you.
-Check this thread out on superchargers-
https://www.ford-trucks.com/forums/s...d.php?t=262698
Old Jul 28, 2004 | 09:13 AM
true4.2's Avatar
true4.2
I posted his reply in a different thread so we don't clog this thread up.
Old Jul 28, 2004 | 09:17 AM
true4.2's Avatar
true4.2
Power suggestions & advice cross-thread
This was posted in the performance sticky thread, so I posted it here to save room.
The list that we gave you is definately NOT useless to you. A diablo chip hands down is one of the best upgrades for WAY under $1000 for you to do. This chip especially makes a difference in the automatic transmission. Buy the chip from www.motorhaven.com . It's pretty much gauranteed to 'make your day' so to speak. It improved Tom's (another 4.2'er) supercab 4.2 by 4 tenths of a second in the quarter mile. That's pretty much unheard of.
Other than that, exhaust upgrades are always a good plus.
Old Jul 28, 2004 | 09:45 AM
horizonhuskies's Avatar
horizonhuskies
You could do 4.10 gears and t-loc for about 750 dollars installed. Get a custom chip or tuner for 200-350 dollars, that will make your drive more enjoyable. On a side note, where in Az?
Garrett
Old Jul 28, 2004 | 10:10 AM
BrianA's Avatar
BrianA
MODERATOR'S COMMENT:
I split and merged threads to make one. Take it from here!
Old Jul 28, 2004 | 12:47 PM
homer4.2's Avatar
homer4.2
How do you split and merge??
Old Jul 28, 2004 | 02:22 PM
true4.2's Avatar
true4.2
You have to have a hammer and a chizzle (sp?). And you have to be a moderator.
BTW, thanx Brian.
Old Jul 28, 2004 | 03:25 PM
BrianA's Avatar
BrianA
I could tell you. But if I told you, I'd have to kill you.
Old Jul 28, 2004 | 04:30 PM
horizonhuskies
Tell him...please.... jk!
Old Jul 28, 2004 | 04:58 PM
homer4.2's Avatar
homer4.2
ok nevermind then, i guess
Old Jul 30, 2004 | 01:55 AM
Jimmy Dean's Avatar
Jimmy Dean
OK, my 2 suggestions, chip and gears. would also, if you an afford it, exhaust and intake, yes those are the 4 typical upgrades, but they REALLY help with your torque curve ALOT, especially those gears will make hill climbing alot easier. If you are going up mountains you need an intake to be able to suck in more air as the air will be thinner...and exhaust to get it back out, if you need torque, which it sounds like you do, dont get a free flowing exhaust, make sure it has some restriction to it for low end backpressure as said the chip is a given
Old Jul 30, 2004 | 02:21 AM
Saurian's Avatar
Saurian
As JD said, Chip and gears. 3.73 or 4.10 gears will help IMMENSLY climbing hills. You probably have to downshift to 4th right now just to hold speed up steep hills (Unless you're lazy like me and watch your truck drown to 50mph =P). The gears will give you alot more punch. And the chip, that helps in every way. More power everywhere in your rpm's, better mileage, smoother, everything.
You ought to be able to just go outand find yourself another complete rear axle to throw back there. Find one with Trak-Lok too. Living where you do, why not? No one-wheel-wondering. Any money you have left over...if you can, hit the exhaust a bit. Maybe remove the resonator and muffler? The Cat's give you all the exhaust restriction you need (To promote proper exhasut velocity, maintaining low rpm torque).
Otherwise...as mentioned, 1000 dollars doesn't go very far in the guts territory. Depending on your terrain, the steeper gears may actually BOOST your mileage too. Have fun!
