96 explorer overdrive downshift
Old Jul 27, 2004 | 09:54 PM
kcbrown's Avatar
kcbrown
The explorer I have has got a 4 liter X engine with overdrive. Sometimes when you are driving and it is in overdrive it rumbles when it downshifts. Sounds like you are running over the wakeup bumps on the side of the road. Seems like it makes a difference how much load is on the engine whereas if it is a lazy shift it seems to do it worse, when it comes down hard it does not do it. Make any since? I would appreciate any thoughts on this problem. THanks
Old Feb 15, 2005 | 02:18 PM
t_g_farrell's Avatar
t_g_farrell
I think what you are hearing ( or feeling ) is the torque converter locking up. This usually happens when you are at cruising speed under light loads. Mine makes a rumble, actually more like a low freq vibration, that I can feel rather than hear when it kicks it. If yours is actually making a loader noise then maybe your torque converter needs attention. Someone more knowledgable on the AL4D transmission may know better.
Old Feb 16, 2005 | 08:46 AM
cdolor's Avatar
cdolor
I had this happen on my '96 5.0 AWD. It required a transmission flush an a service bulletin says to add an anti shudder additive. Had my dealer do this (about $90) and within 10 miles of driving it went away and never returned. I previous have had me transmisson flushed yearly because I tow a horse trailer. But the additive made a noticable difference all around.
Good Luck,
Chuck
Old Feb 16, 2005 | 07:40 PM
don96exp's Avatar
don96exp
'96 AWD 115,000 miles, had the same problem, shudder when going in and out of overdrive, had the trans serviced by ford, $99 and shudder is gone.
jmo1son
Oct 24, 2011 07:22 PM
tanker2008
New Member Introductions
Feb 4, 2010 08:39 PM
3trucks
May 24, 2006 11:23 PM
beatupford
Apr 10, 2006 03:25 PM
MTBer
Jan 10, 2005 07:49 AM
