instrument cluster lights...
Old Jul 27, 2004 | 08:31 PM
mtm1972's Avatar
mtm1972
I have an 88 fullsize Bronco. I recently put a speaker amp under the driver's seat and grounded it to the seat frame. Since then, my dash lights keep blowing the fuse as soon as the lights are turned on. The amp power is drawn directly from the battery. Could the amp be my problem or is it a coincidence. How would I track the overload???
Old Jul 27, 2004 | 10:54 PM
Franklin2's Avatar
Franklin2
I am guessing the amp has a trigger "on" wire from the stereo? And if so, are you sure you hooked this trigger wire to the right place at the stereo? I think most of the time you hook the amp to the electric antenna wire. Or possibly when messing with the stereo wiring, you got a wire shorted against the dash somewhere. The stereo does have an illumination wire from the dash lights going to it.
Old Jul 28, 2004 | 08:18 AM
mtm1972's Avatar
mtm1972
You're right, my receiver has the "remote" wire (blue) that would normally go to a power antenna. It is connected to the right spot on the amp though. The radio lights are fine, as are the warning lights. I guess I'm going to have to dig around a little bit...
Garrett248
Jul 18, 2014 07:13 PM
jb65542
2004 - 2008 F150
Oct 22, 2009 06:35 PM
rat49f6
Jul 30, 2009 11:44 PM
txlnghrn
Jun 23, 2003 02:50 AM
