Aerostar Ford Aerostar
throttle position sensor tps voltage check
Old Jul 27, 2004 | 07:19 AM
trk pny's Avatar
trk pny
I have a 94 3.0L aerostar and it has been acting up some. I pulled the codes with my scanner and got code 53. throttle sensor voltage too high. bought a new sensor and going to install it. before I do I was wondering about "dialing it in". does anyone know if you are to check the voltage to the tps and adjust it before tighting? I know that there is some play in the screw holes. turning it clockwise raises the voltage. I have a mustang that I read some tech tips about and it had a tip on setting the tps voltage to .96-.99 for best results key on engine off . does the 94 3.0L aerostar have or benefit from this also?? thanks
Old Jul 31, 2004 | 10:22 AM
mojo hobo's Avatar
mojo hobo
I own a 94 3.0 I changed the tps and do not believe mine had any adjustment,must depend on the type of intake I guess?If you have any info keep us posted.I don't know about you but had a hard time taking off one of the screws,modified them with allen heads,remember to have the same amount of threads and lenght,bought them from a hardware store that deals with all types of specifque screws and bolts,not to worry but just be observant.The modification was just my personal touch,optional.
Mojo Hobo
Old Jul 31, 2004 | 10:36 PM
trk pny's Avatar
trk pny
Unhappy
my screws were hard too and I replaced with 8mm hex head type. code 53 is still present (TPS voltage too high) , even though I "dialed in" the old sensor and drove the van some. replaced with new sensor and no change. measured voltages and all fall within limits set in service manual. even cleared all codes and disconnected battery for several minutes. started the van and code 53 was there.? looks like something else is broken. I guess I will seek help at the Ford house.
Old Aug 1, 2004 | 06:51 AM
mojo hobo's Avatar
mojo hobo
Just a suggestion.
I may be wrong but I heard when you disconnect the battery,disconnect the neg.and step on brake pedal,drains all the power.I'm really not sure so if someone can correct me please do,like I said just a suggestion.
Mojo Hobo
Keep us posted
Old Aug 1, 2004 | 07:25 AM
Bob Ayers's Avatar
Bob Ayers
Originally Posted by mojo hobo
Just a suggestion.
Mojo Hobo
Keep us posted
Very true!!! You need to provide a current path to discharge the filter capacitors internal to the PCM. You can either hit the brake pedal, or turn the light switch on.
Old Aug 1, 2004 | 09:30 AM
Racerguy's Avatar
Racerguy
At one course I took our instructor told us that the best way to discharge the capacitors is to, with a battery terminal off, touch the positive and negative battery cables together.
Old Aug 1, 2004 | 11:44 AM
trk pny's Avatar
trk pny
I will try to clear all the code again and also drain the capacitors as suggested. I am also going to inspect the 60 pin connector. hope some of this helps. the Ford house is sure to charge big bucks to do this. thanks
Old Aug 1, 2004 | 11:54 PM
trk pny's Avatar
trk pny
well not sure what I did but the code is gone. maybe my diligence has paid off. cleaned all the electrical connectors at the TPS and the 60 pin. cleared all KOER code and disconnected the battery / drain capacitors. reconnected all and double checked the entire thing. code is gone. still need to drive and check performance but is looks good so far. thanks for all the support.
Old Aug 2, 2004 | 09:46 PM
mojo hobo's Avatar
mojo hobo
trk pny
Happy to hear it worked out and you kept us posted.
Mojo Hobo
Old Aug 3, 2004 | 05:17 AM
Bob Ayers's Avatar
Bob Ayers
Dave, that would be the best way.....providing the best possible current path to discharge the internal PCM capacitors!!
