Sponsored by: Kumho
Tie Rod Ends
Old Jul 27, 2004 | 12:14 AM
wickymustang's Avatar
wickymustang
Tie Rod Ends
How do I know if I need new outter tie rod ends? What is the easiest test to see if they need replacing? Obviously if the boots are gone I know I need to, but beyond that?
Old Jul 27, 2004 | 12:40 AM
cbsaf's Avatar
cbsaf
Mine went out a while back. If the truck is ever on a lift the end might move up and down a little or if you're checking from the ground it will have little resistance when you rock it back and forth. I saw mine when I took a pry bar and placed it over a peice in front of the tie rod and tried to force the end upward. My passenger side would go up and down about 1/4 inch and the drivers side was firm. Don't push too hard on a pry bar though if you go that way. Use about as much pressure as it takes to crush an aluminum can. You don't want to pop the whole end off.
