Fuel Tank Mods
Old Jul 26, 2004 | 09:43 PM
01stroker's Avatar
01stroker
Fuel Tank Mods
Did the fuel mods this weekend! I am glad I did it. I replaced all the o-ring fittings all the way from the tank to the pump. I removed the mixing chamber in the tank and extended the return line away from the pickup. I did put my pickup back on. When I started it back up and got all the air out it ran much quieter. It also started like normal. Before i did it when the fuel got down to about 1/4 tank it started and sounded awful.
I also cut off the fill vent pipe. Filled up at the big rig pump wide open, clicked off and I put in a little over a gallon in about a minute. GREAT!!
Thanks Kwiwordead for the idea of getting rid of the air leaks.
Steve
Old Jul 26, 2004 | 10:57 PM
Kwikkordead's Avatar
Kwikkordead
Steve
You're welcome. I must pass the credit for all those ideas to TexasTownCar and Hutch for all thier hard work on this. I was reaping the benefits of thier efforts and now so are you. What a difference!!
Old Jul 26, 2004 | 11:44 PM
wants_a_power_stroke's Avatar
Kwikkordead, do you know if there's a guide on the Web showing how to do
either of those mods? I just bought a 2001 F-250 and I don't want to run into this problem. Mine is pretty quiet, but I have yet to get it below 1/4 tank.
I would much rather do either one of those mods than replace the injectors and/or injector pump. Thanks for your help.....
Chad
Old Jul 27, 2004 | 08:39 AM
belz's Avatar
belz
I did the mods too. Only I left the mixing chamber but did modify it in a different way that is supposed to give the same results. Now I just gotta str8en out my bed. I didnt do a very good alignment job putting it back on, lol
Old Jul 27, 2004 | 08:41 AM
Kwikkordead
Post deleted. Saw your other post Wants_a_psd
RRranch
Jul 22, 2011 05:54 AM
Izzy351
62
Oct 24, 2007 03:15 PM
idifamilycab
Jul 2, 2007 09:04 PM
ac700wildcat
27
Nov 26, 2006 04:12 PM
MikeGV
Dec 4, 2004 10:50 PM
