installed the clamp [mod 10k ]
Old Jul 26, 2004 | 07:31 PM
kens crewcab's Avatar
kens crewcab
i have a 96 psd with 320,759 miles i installed the clamp [ mod 10k ] the truck runs great down low but at wot it surges , installed with a switch so it can be turned of when i do turn it off the truck stops surging any help please
Old Jul 26, 2004 | 07:36 PM
Phydeaux88's Avatar
Phydeaux88
You might try the folks at DieselStop . for help on this there seems to be more of them running it than in this forum
Old Jul 27, 2004 | 08:10 AM
fordnut74's Avatar
fordnut74
A quick guess would be that with the clamp mod, you are increasing your HP oil more than you would with the 10k. THe older 94-97 psd's have a lower capacity HPOP and at the higher RPM's you may be running out of sufficient oil volume/pressure to maintain that level of injection. I would try putting a 1k-5k potentiometer(variable resistor) in line with your switch and adjust it to the point where the problem resolves itself.
