I'm really perplexed. Two years ago, I bought a quart of Dupont Centari single stage acrylic enamel. Last week, I took the old custom mixed can with label to the same paint vendor for another quart - same paint, Dupont Centari. The old label said to reduce 1 part to 2 parts paint (50%). The new label says 8 parts paint to 2 parts reducer (25%). Has something changed in paint formulation that would require such a drastic difference in the amount of reducer used? What would you pros recommend?
I've used a lot of Centari, but not recently, and haven't seen the 8 to 2 directions. They've probably changed it some way. You said you took the old can - I assume it was empty, and you weren't planning on mixing the old and new paint. I'd follow the latest directions.
I guess I'm just an old cynic, but it seems like Centari lost it's shine just after the new urethanes came out in the late 80's. I think paint compainies play marketing games just like any other business. From the time it was introduced untill the mid eighties, an amatuer could make a Centari job look like a piece of wet candy. After a couple of so-so jobs in the late 80's, I quit using it, unless I found a use for some leftover on the shelf, then I would clear it with a budget clear.
Just back from vacation, sorry for the delay. Thanks to all for the replies. I mixed it 8:1:2, same as Aekisu's AE. It went on okay, but there seemed to be far more orange peeling than I had with the older version.
Thanks Jeff for the affirmation of the more noticeable orange peel and the comments regarding the increased reducer. I would have to agree, doubling the amount would give a better flow and finish.
