1978 - 1996 Big Bronco
Cruise Control Not Working
Old Jul 25, 2004 | 09:48 PM
nelly781's Avatar
nelly781
I REPLACED MY IGNITION NOT TOO LONG AGO ON MY 88 BRONCO W/ 5.0L AND IT WORKED FINE AT FIRST. BUT NO CRUISE CONTROL. MY CRUISE CONTROL WORKED FINE AT FIRST. BUT NOW I CAN CRANK THE TRUCK THE ENGINE WONT TURN OVER UNLESS I PUSH FORWARD ON THE TOP PART OF THE STEERING WHEEL. WEIRD ISNT IT? I WOULD LOVE SOME ADVICE. THANKS ALOT GUYS.
Old Jul 31, 2004 | 12:28 PM
Trublufords's Avatar
Trublufords
What do you mean by- I replaced my ignition.Key mech ign. switch-elec. ign switch- ign coil- ign wires-etc.Ford had a recall on 88s elec.ign. switches- also, is it a tilt column?? Brushes under steering wheel poss. prob. Cruise switches in steering wheel poss. Cruise servo bad poss Actuator cable broke or unhooked poss. Fuse blown poss No start with faulty switch(elec) would run with key turned in starter crank position- holding it there- you need someone out in engine comp to pull off energize wire to start solenoid to keep from burning up starter-if switch is problem. Good luck!!!
F250saleen
Electrical Systems/Wiring
Jan 11, 2010 06:48 PM
octaneforce
Nov 19, 2009 07:57 PM
texastransplant
1997 - 2003 F150
Feb 10, 2009 12:31 PM
BlackJeep
Nov 9, 2008 06:32 PM
MikerMan
Sep 19, 2002 06:24 PM
