Sponsored by: Real Truck
Help!! V10 Problem
Old Jul 25, 2004 | 04:58 PM
Shmokie2's Avatar
Shmokie2
Help!! V10 Problem
I have a 99 super duty crewcab with the triton V10 and I am having trouble with it. When it warms up on the road it boggs down like it is starving for fuel or o2 when I kick down into passing gear. If I shut it off and restart it its fine for a while. Fuel filter was changed and no codes are registering on computer. Any ideas????
Old Jul 25, 2004 | 07:42 PM
slc10844's Avatar
slc10844
Sounds like you might have a clogged catatylic converter.
Old Jul 25, 2004 | 08:07 PM
Racerguy's Avatar
Racerguy
Hi Shmokie and welcome to the forum
How many miles on your truck?
Ever clean the MAF sensor?
To see if it's the catalytic converters like slc said you can loosen the nuts that hold the Y-pipe to the manifolds and drop the exhaust down enough so there is a big leak then drive it and see if it makes any difference.
Old Jul 25, 2004 | 08:25 PM
Brian_Puff's Avatar
Brian_Puff
what about the air filter... it could be plugged also. its somthing that is overlooked alot i think.
maybe its time for a k&n intake, headers, high flow cats and flowmasters... tell the wife its the only thing you can do
