1978 460 engine chatter, rattle
Old Jul 24, 2004 | 06:48 PM
WillySixGun's Avatar
WillySixGun
Hello,
Thanks in advance for any help. I have a 78 F250 with
a 460. When I accelerate hard I hear a chattering sound from
the engine compartment. Once the engine is warmed up this
stops. The is very temperature dependent. In the winter it
does it more and less in the summer. Any ideas? *****
Old Jul 24, 2004 | 07:08 PM
Mil1ion's Avatar
Mil1ion
Welcome to FTE!
IMO, Fuel delivery or choke system.
I'll move this thread to the fuel delivery forum.
Old Jul 24, 2004 | 07:33 PM
AirSmitty's Avatar
AirSmitty
Sorry man but you're in the wrong forum. A 460 is in the 385 series of engines. They have a forum on this site, and i'm sure they could help. Sorry I can't help more. Good Luck!
Old Jul 24, 2004 | 08:44 PM
EgoMan's Avatar
EgoMan
I have no clue.....Stickey valves....lol Sorry I suck.
Old Jul 24, 2004 | 08:52 PM
ranger429's Avatar
ranger429
Does it sound like more of a tapping? Or does it sound like a pinging? Is it a stick shift? Hard to diagnos a chatter sound over the internet.
Old Jul 24, 2004 | 09:04 PM
WillySixGun
Sorry, wrong forum. It sounds like the chatter, like metal slapping together.
I thought it might be the choke flap slapping, but there is no drop or increase
in power when it is doing it. Once in the dead of winter is was very cold
and it would make the noise during idle. I was able to listen to it with the
hood open. The sound was common from the front of the motor. I thought
it might be the water pump. I checked the pump barring and it did not
wobble with the belt off.
So the noise is comming from the front of the engine. The colder it is outside
the worse it does it. Once the engine is good and hot it does not to it.
Thanks, *****
Old Jul 24, 2004 | 09:09 PM
ranger429's Avatar
ranger429
Did you check the fan clutch? All I can think of
If the bearing goes bad in the water pump you will know, it will leak anti-freeze all over as it will cause the seal to blow.
????? You got me....
Old Jul 24, 2004 | 09:20 PM
WillySixGun
The clutch fan is relatively new, but that does not mean anything. I'll give it
a look. Any idea how I can rule the clutch fan out? Take it off and see if
the noise goes away? *****
Old Jul 24, 2004 | 09:25 PM
ranger429's Avatar
ranger429
There are 2 types of fan clutches, centrifugal and thermostatic. the thermostatic turn's fairly tight untill it is warmed up and it turn's easier the warmer it get's, the centrifugal, self explanatory. there should be no abnormal binding, or chatter coming from there.
Old Jul 24, 2004 | 09:28 PM
Mil1ion's Avatar
Mil1ion
As my first reply had stated...I believe it to be a fuel delivery problem (Choke)
Old Jul 24, 2004 | 09:57 PM
Torque1st's Avatar
Torque1st
Posting Legend
Moved to 73-9 for the experts.
Old Jul 24, 2004 | 10:00 PM
WillySixGun
If it is the choke, wouldn't there is some change in power? I feel
no difference in acceleration. Just hear the noise. Thanks, Bill
Old Jul 25, 2004 | 01:27 AM
TheImpaler's Avatar
TheImpaler
Bad lifter?
A lifter will give you more a ticking sound than a metal-metal sound, but those symptoms seem to be in line with my "lifter-tic" experiences.
-Patrick
Old Jul 25, 2004 | 02:20 AM
Hypoid's Avatar
Hypoid
Originally Posted by WillySixGun
it might be the water pump. I checked the pump barring and it did not wobble with the belt off.
Thanks, *****
Did you push and pull the shaft to check end play? Just kidding, what you describe could be anything from a worn out distributer shaft letting the rotor hit the cap to a loose piece of sheet metal to the motor shaking enough to let the fan hit the shroud.
My real advice is to get one of those "mechanics" stethoscopes and try to isolate the noise. The low buck approach is to use a long piece of rubber hose, one end to your ear, other end to the motor. It's actually kind of fun to poke around and identify the parts as they work.
One other thing, watch out for moving parts. I never heard a machine say "ouch".
Old Jul 25, 2004 | 03:49 AM
Torque1st's Avatar
Torque1st
Posting Legend
Many posts spammed into many forums combined into one thread.
