Yesterday fixed broken plug and exhaust.
Start her up and she runs fine ( no sparkplug bits in engine. )
Rev it a little and she leaks GAS from above the tank.
I need help dropping the tank and things to look for
How did you fix the exhaust? Did you watch out for the fuel lines if you were welding/cutting/drilling? All I can think of is a broken hose/cracked tank that would cause that.
Correct me if I am wrong, but I believe there was a recall on the fuel tanks for leaking. Maybe someone else could be more specific.
I have not had to pull down on the a gas tank bolt, but I have never pulled a tank off of an Aero either, so it might be normal. Are they really rusty? Is so, you might have to cut them off.
