new/old topic with a specific question.
If I were to open the intake, exhaust and chip it, will the horsepower/torque gains at allow me to pull at the higher speeds and still stay in overdrive? I know I am looking at small numbers here but on a 2000 mile trip I could save $130.oo at the 9 mpg versus the 7 mpg at $2.00 per gallon. Any thoughts?
As a side note I have 3.73 gears, if I had 4.10's it would allow me to pull in overdrive at the higher speeds but would increase my rpm somehwhat which would negate the gains in mileage.
$400-$900 exhaust
$250-$410 for chip
$650-1200 for gears
Best gain possibe and reported here is about 2mpg. Most folks actually loose mpg and gain a lot of higher rpm power.
I liked the preformance from the fatory for my 85% usage of around town and short trips unloaded.
To get better power and milage for the four or five times a year I hauled a lot of wieght a far distance were not worth the time trouble and $$$$, for me.
I would not do the gears and since I do a lot of ebay stuff for the intake and chip I can get to the lower range in cost it would take approx two years for my return on invetsment using your cost factors. I usually keep my vehicles for a minimum of 5 to 7 years so this now adds up long term. If gas continues to increase the savings are bigger if not then smaller. I appreciate all theinfo you have provided very helpful.
This is because Ford, Chevy, and Dodge are required to make the gasoline engines lighter, quieter, and more efficient. Not so of the Diesel motor family. By design the V8/V10 family is already near it’s best potential. The Diesel has much more potential. The manufactures deliberately detuned them so they would not have to add the expense of other drive components that can handle the increased torque loads. They don’t talk about it much, but a lot of the diesel guys that went on steroids had to spend big bucks to get their trannies bullet proofed. You send 800ftlbs of torque through a drive train rated for 600ftlbs and stuff is going to break
V10 Has lots of grunt down low and really comes alive around 3600RPM! This is NOT too high an RPM to cruise at. If you had a 500Cubic Inch Gas motor with another 100ftlb of torque then at 1900-2300rpm you would have plenty of power at OD cruise but it would cost in reduced MPG.
My 2001 V10 4x4 4dr 3.73:1 LS, Harley super glide in bed, 9000lb TT loaded, three adults, and Pete the Boston terrier all combine to put my truck over the max tow able. I do some very steep long grades getting from central Texas up to the mountains of Colorado, Utah, Arizona, and parts west. I punch off OD and sometimes down shift and run the motor up to 3600-4800Rpm to keep above 60 and frequently get long runs at 67-73mph. My MPG sucks on these trips but is still much better than I ever got with my “old school” carbureted 460CI F250.
You getting 6-8 MPG is pretty good, and the only real way to get much better is the PSD. They shine at hauling a load, as that is what they are built for. For us occasional haulers the V10 is the best compromise.
I ordered a new 05 F350 with 4.30:1 gears and the new V10 and 5speed auto combination. She will be perfect for what I want to do. And quite frankly at this level of comfort, speed, coolness, I don't really give a rat’s *** about the fuel costs. I am not taking a shot at you, just giving another perspective. If you NEED more power to haul the hills go for it, but accept that there is little you can do to gain significant MPG increases in the SuperDuty, but haul lighter and slower... hell that isn’t any fun, and you will drive yourself nutz chasing a couple of hundred dollars a YEAR fuel savings... not worth all the pain. Get out there and drive that rig like you stole it! And have a ball camping at the beach!
Sold the 01 dyna sport, used the proceeds to buy the trailer. Owned H-D's since 1984. Planning for the purchase of the next one. My boys are 9 and 10 and I figure I've got 3 to 5 more good camping years. Hopefully if I save enough on motel rooms and gas
and the trailer holds a decent value I can scratch enough together to buy a new one at that time.
