Recommendations for engine trans
Old Jul 23, 2004 | 12:14 PM
46fordtruck's Avatar
46fordtruck
I'd like to use my '46 for towing, usually just project vehicles to move from here to there. What are my best bets for a somewhat economical engine and trans combo? I'd like to keep it an automatic, and all Ford. I need something that can do the job, but not suck up tons of gas (i.e. no 429 or 460).
Old Jul 23, 2004 | 02:39 PM
V-104Me's Avatar
V-104Me
If you keep the weight below 6k, I would think a 351W would be a good choice. Find a C6 for a small block and you'll be in business.
Old Jul 23, 2004 | 05:21 PM
SoCalDesertRider's Avatar
SoCalDesertRider
An old friend had a '53-ish Ford pickup with a 272 or 292 Y-Block. That truck had some ***** too. I think it would be cool to stick with an engine of similar vintage as the truck, build it up and see how it does .
Old Jul 24, 2004 | 06:13 AM
jowilker's Avatar
jowilker
Socal, ya better watch your potty posting, ol dieselJohn will be upset with ya.
46, You might entertain putting your sheetmetal on a newer chassis. I have always thought those were pretty kool. 351W auto with OD, tilt, AC, power everything. King of the road kinda thang.
My 2
John
Old Jul 24, 2004 | 12:01 PM
46fordtruck
I was thinking of a 351W too, but wanted to get opinions. Putting the truck on a later model chassis is out of the quesiton for me. The truck isn't going to be a dedicated tow vehicle, just something to drag my family's other projects around when needed. Thanks all.
Old Jul 24, 2004 | 02:12 PM
fellro86's Avatar
fellro86
form the description of your intent, I will agree the 351W is the best choicem relatively cheap and available. Overdirive is doable, but a C-6 is durable, and once again the cost is reasonable. I got 12 mpg out of that combo in my parent's E150, so judge accordingly. I can't answer on what gear it had, though, but it did ok towing a 20 ft Winnebago.
Old Jul 24, 2004 | 05:22 PM
johnsdiesel's Avatar
johnsdiesel
That's not my rule, it's part the the FTE rules. You should show a little more respect toward the forum guidelines since you're a moderator. I would also appreciate it if you would stop baiting me with those kind of statements, something else you should recognize as inappropriate as a moderator. I'm not trying to moderate a moderator, but show me some simple courtesy and respect or don't respond to my posts at all.
Old Jul 25, 2004 | 01:47 AM
Rory's Avatar
Rory
whell here is my 2 cents 460 c6 with 25% reduction in gear and a over drive unite-douge nash etc...I have a 7000pound dump truck with a 351m and I can hange with most sports cars off the line, you should see there face when I go by them 4.10 gears and smile all the way by
Old Jul 25, 2004 | 01:58 AM
Rory's Avatar
Rory
but did I mention I get 13 mpg I dont think thats to bad
Old Jul 26, 2004 | 12:31 PM
superrangerman2002's Avatar
superrangerman2002
what ever you go with, make sure that you have a good brake system.
Nothing worse than having to slow down 4 mi before the stop sign.
Old Sep 19, 2004 | 07:00 AM
Loan Ranger's Avatar
Loan Ranger
I think a 351 Windsor, a C6 automatic, a 9-inch Ford rear end, and auxillary transmission cooler would be great. I would make sure I had the 61-amp Ford GPD alternator at the very least and I would make wiring provisions for lights and trailer brakes.
Insofar as looks go, I think a bit of dress-up chrome under the hood--brackets, valve covers, air cleaner, and fake braided hose--would rather match the chrome of the grille and the like. It would seem to me to be a great--and practical--mixture and use of the older with the newer.
If you do decide to do these things as have been suggested to you, please do post pictures of it all!
