Sponsored by: Innova
2002 Crew Cab Video System
Old Jul 22, 2004 | 11:33 PM
WazzuF350's Avatar
WazzuF350
Has anyone found a vehicle specific flip down monitor for the crew cab? Does the excursion roof line match the superduty crew cab (ie, will the flip down specific for the excursion fit the crew cab?).
Is the stock radio a Din and a half or a double Din opening? I have an in dash dvd player and wanted to know if I can add an indash flipout monitor in the stock opening?
I have been looking at several lower tier manufacturers (power acoustik, pyle, etc.) and it seems like they have the same units as the higher price manufacturers, does anyone know if these units are worth buying?
Thanks
Old Jul 26, 2004 | 12:33 AM
mzimmers's Avatar
mzimmers
I'm assuming that your 2002 is essentially the same as my 2001.
The radio cavity is not 2-DIN; the cavity slopes inward after a couple of inches. When I looked at mine, it appeared that I could cut away the back of the plastic piece that frames the radio cavity, and make plenty of room for two DIN devices, but you'll want to double-check that before pulling out your handsaw.
If you don't like that idea, you can get an all-in-one CD/DVD player/monitor. They're not cheap, but I don't think they're much more than the individual components.
I can't help with whether the Expedition overhead will fit...if you find out, let us know.
Old Jul 26, 2004 | 09:37 PM
WazzuF350's Avatar
WazzuF350
I already own the in dash dvd player and did not want to invest in another device other than the in dash monitor. I would assume that the opening is designed the same as the 01 crew cab.
