General Automotive Discussion
i hate computer controlled, efi vehicles!!!!
Old Jul 25, 2004 | 07:30 PM
Torque1st's Avatar
Torque1st
Posting Legend
Sound difference is probably the Cat, cam and other exhaust system differences.
Old Jul 26, 2004 | 09:59 PM
benwantland's Avatar
benwantland
as for starting... I know an EFI vehicle will always start up the first time you try, but if you have a well tuned carb engine, it doesn't have to crank as long to do the same thing. A touch of the key, tap on the gas to give an accel pump shot, and you're running, except in mega-bad weather. Trust me, I've driven my share of both... you can go to wantlandracing.com and see some of the vehicles I own/have owned/work on/play with/etc.
Next time you get in your EFI car, just tap the key to start for a second... don't hold it, just a tap. See if it starts. It won't, because it hasn't even built fuel pressure yet. It's not that it's not more reliable; it probably is, I just love the feeling of having my engine fire the instant the starter engages, and there is no way to have that without having some fuel always sitting right there on top of the engine.
The problem with efficiency in carbs is that they don't continuously correct the amount of fuel they give the engine based on real time inputs, I'll give you that. I still say it's more efficient to have that self-atomizing fuel though. Anyway, it is possible to closely approximate normal driving conditions when setting up a carb, and it shouldn't get dramatically lower mileage than a comparable EFI engine.
As for moving parts, although FI is electronically controlled, it is still a mechanical process, and a more complicated one, I believe, than carburetion. In a few years, when stuff starts wearing out, you start swapping fuel injectors, and I'll start rebuilding my four barrel at the same time, and we'll see who gets done first.
It's all in fun man, and the way you look at it. Some things are simpler to some people, but more complex to others. To each their own, I say.
Old Jul 26, 2004 | 10:46 PM
85e150's Avatar
85e150
Hey, wait till they get that electronically controlled valve thing going. Where you don't need a throttle anymore, because they control the idle with the valve opening.....
Old Jul 26, 2004 | 11:26 PM
Torque1st's Avatar
Torque1st
Posting Legend
You mean the IAC??? Idle Air Control motor or solenoid whichever the case may be... They do have drive by wire now with no link from you to the throttle. Just a variable resistor under your foot.
Old Jul 26, 2004 | 11:29 PM
85e150's Avatar
85e150
Yes, I knows about that. But this is the next step, or maybe three steps beyond that: I'm talkin' the intake and exhaust valves are electronically controlled. No cam or any of the other flying junk that connects it to the valves.
Try to tune that baby with a screw driver and a match book striker.
Old Jul 26, 2004 | 11:44 PM
Torque1st's Avatar
Torque1st
Posting Legend
They already have electronically controlled valves in some engines. I do not know if they are in any production vehicles tho.
Old Jul 26, 2004 | 11:47 PM
85e150's Avatar
85e150
Racing motors maybe.... or research. Also, I think some formula cars use air to activate the valves....kind of noisy...
Old Jul 27, 2004 | 12:28 AM
Torque1st's Avatar
Torque1st
Posting Legend
I have read about two types, one was direct electromechanical actuation and the other one was hydraulic. An engine already has a built in hydraulic pump
Old Jul 27, 2004 | 06:08 PM
250-1968_campspecial's Avatar
dude spend 1000 (?) or so dollars coverting ur computer controlled motor to a carp one
Old Jul 28, 2004 | 12:30 PM
evilbeast's Avatar
evilbeast
the closest thing to a computer in my truck is the cd player and the amp. unless you want to count the electronic ignition, i have no use for a computer controlled car. that is what a good trained ear, and actually payin attention to your vehicle can do for ya, instead of waitin for a light to come on, and have somethin even bigger pop up, just my .02, hope i didnt offend
Brownrp92
17
Dec 9, 2016 06:53 AM
3rd-coast-thumper
New Member Introductions
Oct 24, 2016 02:28 PM
zach6050
Jun 3, 2016 11:58 AM
Tkelly44
Aug 14, 2015 08:28 AM
F100_77
Jul 22, 2003 05:11 PM
