Upper Plenium Intake slightly damaged
Old Jul 22, 2004 | 01:23 PM
free90xlt's Avatar
free90xlt
Hello,
Well fixing a bad "repair" by a previous owner, we had to drill the top off of the torx screw in the center to get the upper plenium off. While my brother in law as operating the drill he put a couple of minor gouges in the intake, but the more serious one is area where the afflicted bolt seats. It was drilled about a third of the thickness through from the inside edge of the bolt hole to the outside edge of the upper intake.
Will this gouge give me any problems with leaking, improper torqueing excetera? The lower mating surface appears to be purfect. Also, since the actual intake was cross threaded do you think it can still be safely used and if needed would it be possible to rethread it slightly larger?
The initial reason for the repair was for a major vacuum leak that I believe was caused by the fact that the torx bolt was cross threaded, stripped and about a quarter inch out above the intake. I do have a donor truck with matching engine but I don't want canabilize it yet as it is a well running motor and I don't think my motor has any "major" problems yet.
Thanks for any suggestion and opinions
Mike
Old Jul 23, 2004 | 02:43 PM
free90xlt's Avatar
free90xlt
Any recommendations?
Old Jul 23, 2004 | 04:19 PM
Kemicalburns's Avatar
Kemicalburns
get a new upper off of ebay. i see them cheap all the time.
Old Jul 24, 2004 | 07:55 PM
free90xlt's Avatar
free90xlt
Well, i couldn't find an upper at the moment, but well looking at the intake, I discovered that when the bolt was cross threaded, they cracked the intake in three places.
The good news is I bought one on ebay for 38.00 after shipping.
Mike
Old Jul 26, 2004 | 09:51 AM
Kemicalburns
Ebay is great for stuff like this. when you get the upper intake get it hot tanked so all the carbon is removed from the inside before its installed.
late
Coccyx
Jun 22, 2024 02:30 PM
texun
1997 - 2003 F150
Oct 5, 2008 04:14 PM
MRL123
Feb 19, 2007 11:32 PM
BigRedBronc
1978 - 1996 Big Bronco
Mar 18, 2006 07:19 PM
free90xlt
General Automotive Discussion
52
Nov 22, 2004 08:59 PM
