Another oil pressure question.
Old Jul 22, 2004 | 10:18 AM
nd48463's Avatar
nd48463
After replacing main and rod bearings i have much better oil pressure, but it takes several minutes to build up. I used 10w-40. With the new bearings, should i maybe be using a thinner oil? Would that have anything to do with building oil pressure? When I start out it is very low, then after 5-10 minutes it is great. Usually pressure drops after the engine warms up?? I do have a mechanical gauge, but have not installed it yet. Maybe tonight.
Nate
Old Jul 22, 2004 | 11:47 AM
pfogle's Avatar
pfogle
I would check it with a mechanical gauge first, but you should have installed a new oil pump when you installed the bearings, it's good insurance.
Old Jul 22, 2004 | 12:38 PM
nd48463's Avatar
nd48463
I did install a new pump.
Nate
Old Jul 22, 2004 | 06:05 PM
pfogle's Avatar
pfogle
then it sounds like maybe it's a faulty sending unit. or clogged(ing) pickup.
