Question
Old Jul 22, 2004 | 10:15 AM
meierotto's Avatar
meierotto
Question
Hello,
Can you put a transmission out of an 88 F-150 that is 4x4 into a 2wd truck because my 2wd truck dropped the tranny and i have a 88 4x4 thats is bein junked. Well let me know at meierotto_15_@hotmail.com thanks
meierotto
Old Jul 22, 2004 | 11:10 AM
Big Orn's Avatar
Big Orn
Sure, but you'll need to install the transfer case with it - unless you have the parts to change them over (rear housing).
Are the two trannys the same type? If so, just change out the guts.
BTW - welcome to FTE
PS - This may get moved to the transmission forum below...
Old Jul 22, 2004 | 01:32 PM
faroffthetrack's Avatar
faroffthetrack
Well if the trannys are the same why dosn't he just switch out the rear housings instead of the guts?
Old Jul 22, 2004 | 01:50 PM
Big Orn's Avatar
Big Orn
Heck, you're from Texas, ain't ya'?
That's what I meant...
Take that rear housing and tailshaft and be done with it.
Old Jul 22, 2004 | 05:44 PM
SoCalDesertRider's Avatar
SoCalDesertRider
Swapping the tailshaft may be a little more involved than simply remove and replace, depending on what tranny it is. Might want to call a local tranny shop and ask what's involved in doing the tail swap.
