How many of you pull a 5th wheel with your V10? I have a 2004 F250 V10 LB 4x4 3.73 and would like a 5th wheel but anything over 29' I have looked at seems too heavy.
I pull a 34' 5th wheel. I had 3.73s when i pulled it the first time to Durango Co. Pine Az and back to SLC Ut. I had 4.10 gears put in after that trip. It pulled ok but I was in 2nd a lot on steep hills. If I hit a hill at 80 (much to fast for a 5iver) I could pull many hills in 3rd. The 3.73s are just too tall for 11000 lbs. I like it much better now. See my sig for mods to my 03 SD crew
I have a 10k 31' Fiver V-10 pulls it no problem. Take note of what type of fiver you're trying to pull: Low profile, mid-profile, or high profile. Both Low and Mid Profile fivers aren't that high and are very aerodynamic (easier to pull).
DS and JM, Is your setup over the GCWR for your truck? I'm thinking any 5th wheel over 9K GVWR is too heavy. The GCWR for my truck is 17K. I haven't found a 5er over 29" with under 10K GVWR.
I pull a 30ft 9k dry 5th with my V10 with 3.73 gears no problems. It all depends on the design of the 5th i think. When i go upgrade gears to 4.30 i can add 3k to the weight i can pull.
My F-250 GCWR is also 17,000 (F-250 CC V-10 3.73LS 4x4).
Thus if you add the trucks GVWR and the trailers GVWR (8800 + 10000) then I *could* be over the GCWR (17000) by 1800lbs--*IF* I load up the camper to its max GVWR.
The whole shebang scales out at about 15000lbs with 2 people in the truck, 1/3 tank of fresh water, empty grey/black tanks, full propane, full tank of gas in the truck, and all of our normal camping supplies loaded in the camper (chairs, tables, bbq, etc.).
I'm also about 100lbs shy of the GVWR of the truck due to hitch weight (the wife doesn't like it when I tell her she can't legally ride in the truck unless she looses weight! The F-250 has the camper package with the helper springs: when loaded and on level pavement the helper springs are about 1/2" from their stops (not touching).
I just keep in mind that the camper can go to 10,000 but I can't load it to more than 8,200lbs due to the truck (thus the campers cargo carrying capacity is reduced because of the 17,000 GCWR of the truck).
So I am just under legal, but since the F-250 and F-350 are mechanically the same truck...I don't worry about it...
Maybe I should ask this question in the Towing and RV forum but I'll ask it here since you guys are being so helpful.
So is the total weight of the rig:
truck weight + pin weight + trailer weight or is it just truck weight + trailer weight and so long as truck weight + pin weight doesn't exceed the truck GVWR it is OK?
GVW is truck plus the pin weight. In other words, if you were to pull onto a scale with just the trucks 4 wheels, that's your GVW. To get the GCVW you must weigh the truck and the vehicle you are towing.
For me and my last truck (sorry, I haven't had time to weight the Ford yet)
Truck alone had a GVW of 6800 rated for 9200
Trailer had a GVW of 7180 ratred for 8600
Truck with Trailer hooked up had a GVW of 7780 still rated for 9200 (this is truck plus trailer tongue or pin weight)
Truck and Trailer together had a GCVW of 13980 rated for 16000
I hope this helps.
Hey... I just realized this is my first post here!!!
Tom.
GCWR is only for a TT trailer, I had this same question a while back and got lots of strange info. In effect DOT says a fithwheel is part of the truck, so you have to take the the GVW of the truck and trailer and add them up. So if the truck has a GVW of 10K and the trailer of 10K then you can not weigh more than 20K the GCW does not come into play but the max weight per axel does so you need to weigh the truck and move the hitch or pin to take weight off if you are over the max rear axel weight.
Now this is stuff I came up with from camping sites and talking with some DOT cops but I am pretty sure it is correct.
What you are saying if the total weight of truck is rated at 11000 and trailer is 16100 so I can go to 27100 max. I only go to 22000 now and don't plan to go any higher so I am within limits as far as DOT is concerned, all my axles are within limits also. I've always wondered about that
Daimon1054, are you saying that it does not matter what size 5th wheel I pull as long as I don't exceed the GVWR for the truck (truck + pin weight) and the maximum axle weight rating for the truck?
you guys are talking apples and oranges with what Ford rates the vehicle as and what DOT says is legal.
The truck has a limit of the gross weight it can weigh. This is all the weights combined, truck, passengers, fuel, cargo, and includes pin or hitch weight. This weight directly relates to WHEEL and TIRE load capabilities.
The truck also has a limit on how much it can tow. This relates to the available power and torque of the engine, transmission, rear gears to get it moveing, and the brake HP needed to haul it all back to a stop..
