Explorer Headlight
Old Aug 15, 1999 | 09:15 PM
Karl K.
Guest
Posts: n/a
Explorer Headlight
I have a 95 Explorer EB which recently developed a problem with the Left(driver's) low beam. The headlight abruptly went out and has not come on since. A new bulb does not help. My volt meter tells me there is no power to the low beam at the headlight connector. However there is power to the low beam fuse and the fuse is intact. Any Ideas? my truck is equiped with a headlamp out sensor wich reads that the headlamp is out.
Thanks
Karl
Old Oct 23, 1999 | 08:12 PM
G K.
Guest
Posts: n/a
Explorer Headlight
This should be a simple fix. Don't forget to check your Ground connection at the headlight socket. Try measuring from the 12 at the headlight connector to a known ground point or the neg 12 battery post terminal. Use the ohms/resistance tester to check whether the neg term on the hdlight conn makes it back to ground. Does the high beam work? It takes a bit of detective work, but the circuit is a simple one.
Looking at a diagram of a 92, it looks like if one headlight works, then everything past the "dimmer,flash to pass switch" is ok and its only wiring past that point. In other words, one wire goes to both low beams and another splits to both high beams. Then a ground wire goes to ground from each headlight. thats it.
Old Apr 27, 2002 | 10:07 AM
jkohout's Avatar
jkohout
Explorer Headlight
I have the exact same problem and I am try to troubleshoot it.
Did you figure out what the problem was?
Thanks,
Old May 4, 2002 | 09:33 PM
Greg C's Avatar
Greg C
Explorer Headlight
Old May 5, 2002 | 04:27 PM
duckeyes's Avatar
duckeyes
Post Explorer Headlight
If you are still needing an answer to this problem, here it is...most likely. This is a problem that Ford should have long-ago recalled. I have recently found out that Ford only tracks these problems for about a year from manufacturing date...figures.
Your lamp out warning module probably has bad solder joints. I am not sure exactly where it will be in the 95. I have a 96 EB. It has the center console and the driver information center. You portions of the console and the DIC. On the right, under some mounting apparatus for the console you will find a box held in place by a couple of screws. It is about an inch thick, three inches in length, and two inches in height. It is located near where the passengers left leg would be against the console.
Remove the box, open it up. (If you notice a bright orange sticker with a 1-800 number asking you to call it before replacing the module, don't bother. That is the 1-yr tracking I mentioned.) The box contains a little circuit panel. You can most likely see the bad solder joints from the plug connections to the board, I had two. You can also see, probably, where excessive heat has been handled by this circuit board - design flaw. You can try to resolder the joints. I was able to resolder one, but had to create a jumper wire for the other because it would not solder.
Like you, I found out about this over the net. Ford dealer was no help. I imagine about a $200 repair in their shop if they found it.
Depending on your level of expertise or desire, you may want to replace the unit. I cost about $55.00.
I have some files somewhere that were sent to me. I can try to post if you want. It kind of shows how to get to the LOWM. It was not all that helpful.
I can also elaboate later if you really want to undertake this. This problem can effect one or more different lights, but it is always the same module.
I spent hours looking for the problem in the wiring and rigging bypass wiring until I stumbled across the eureka.
Good luck,
Brian.
deano2
Electrical Systems/Wiring
19
Feb 17, 2018 08:51 AM
kirkharrod
Jun 11, 2015 12:32 PM
Spareparts63
Mar 7, 2015 09:40 PM
Lesalvato616
Feb 17, 2015 02:04 PM
dajo
1997 - 2003 F150
Jan 28, 2015 10:49 AM
