a '94 wiper motor
a '94 wiper motor
[updated:LAST EDITED ON 11-May-02 AT 05:26 PM (EST)]My windshield wiper motor died on my 94 explorer, in a rain storm...of course! After I drove with my head out of the car, Jim Carey style, I went to the junk yard for a new motor. Took the bolts out, yrt the motor did not pop out?! Looks like there is a cotter pin holding the wiper arm to the back of the motor. I can not seem to get to it. The pin is hidden under the peice of truck that is between the hood and the windshield. Do I have to take that peice off? If so where are the bolts holding it on? If not any idea how to release the motor to change it out? Thanks for any help!!!
a '94 wiper motor
Those things require a little work to replace , follow the instructions below .
Removal
Cycle windshield wipers until they are in straight up position, then turn ignition switch to OFF position.
Disconnect battery ground cable, then the wiper motor electrical connector.
Remove righthand wiper arm and blade assembly, then the righthand pivot nut and allow linkage to drop into cowl.
Remove linkage access cover from righthand side of dash panel.
Release wiper motor retaining clip, then slide clip back until it clears nib on crank pin, and remove the clip.
NOTE: The wiper motor retaining clip can be reached through the access cover opening.
Remove wiper linkage from motor crank pin.
Remove motor attaching screws and the motor.
INSTALLATION
Install wiper motor and torque attaching screws to 10-14 ft lb.
Connect wiper motor electrical connector, then install clip onto righthand linkage, ensure clip is fully seated.
NOTE: Do not install linkage on motor crank pin, then attempt to install clip.
Install lefthand linkage onto motor crank pin, then the righthand linkage onto crank pin, pulling linkage onto pin until it snaps into place. NOTE: Clip is properly installed if nib is protruding through center of clip.
Install righthand wiper pivot shaft and nut and torque to 7-10 ft lb .
Connect battery ground cable, turn ignition switch to ON position, turn wiper switch OFF so wiper motor will PARK, then turn ignition switch to OFF position.
Install righthand linkage access cover, then the righthand wiper blade and arm assembly and check for proper operation.
Removal
INSTALLATION
