1999 Ford Explorer Computer
Old May 16, 2002 | 03:16 PM
duketter's Avatar
duketter
I have read that disconnecting the battery so the computer re-learns driving habits is mentioned sometimes. What does this actually do. I do not have any problems with my explorer but bought it used about 1 month ago. It is a 1999 with 19,000 miles on it. Got a good deal and I really like it! Would it make sense to disconnect the battery so it re-learns my driving habits and doesn't use the people's before me that had it??? Just wondering. I just didn't really understand how it all works. Thanks!!!!
Old May 17, 2002 | 09:18 AM
winfordr's Avatar
winfordr
I would not erase the computer memory unless there is a problem. The data stored helps control the idle speed and several other runability factors. If it is erased, it will have to be re-learned, and it will not run as smoothly until that is accomplished.
I would buy or borrow a code scanner and check for any stored codes. If there are none, then do nothing. If some codes are stored, clear them and check again in a few days. You can clear the codes with the scanner, thus preserving the drivability info that the computer has learned.
Winford
Old May 17, 2002 | 02:25 PM
ctruxton's Avatar
ctruxton
indyraven
May 19, 2016 03:05 PM
Ridge
Nov 18, 2015 09:53 AM
KDAVID1
Mar 27, 2015 09:56 PM
fordiesel69
2004 - 2008 F150
Aug 25, 2014 05:14 PM
dynamis5
2004 - 2008 F150
Jan 29, 2007 05:39 PM
