AOD TV rod return spring?
Old Jul 19, 2004 | 03:06 PM
Redone's Avatar
Redone
Do I need a return spring at the carburetor for my TV rod connection? I've looked at all the illustrations that I could find and nothing mentions connecting a return spring. But the lever at the carburator has a hole which looks like a place one would attach a return spring.
http://img56.photobucket.com/albums/...-2022_copy.jpg
Anyone?
Old Jul 20, 2004 | 09:10 AM
51dueller's Avatar
51dueller
Yes you need that or the TV Rod may not return to the throttle stop. It is just a simple spring that hooks in that loop and hooks in the little hole under where your throttle cable is bolted. It is a little peice that is bent perpendiculat to the intake manifold with a little hole in it.
Old Jul 20, 2004 | 10:05 AM
Redone's Avatar
Redone
Thanks for the confirmation!
