1984 tachometer problem
Old Jul 19, 2004 | 07:30 AM
nat123's Avatar
nat123
Unhappy 1984 tachometer problem
I have a 1984 ford f-350 with a 351 engine and wanted a stock tachometer in the vehicle. I found a setup from a 1981 ford f-250 with a 300 six and moved the whole dash assembly in and everything worked fine except the tach. It works sometime and then just dies. Then a couple days later it works a little and then stops again. I checked the ground connection and the hot to the tach and these are fine. The tach wire seems ok physically but I'm not quite shure what to do next. Anybody with any suggestions? could it be that the tach that I am using from the 6cyl ford has issues now being in an 8cyl vehicle??
Any help would be appreciated. tc@maine.rr.com
Old Jul 19, 2004 | 09:27 AM
Oscar Meier's Avatar
Oscar Meier
I would double check the ground wire and also try cleaning the circuit board connector & plug. If you didn't have a tach, you may have a corrosion problem. You can try a good clean pencil erasure on the circuit board and plug or you can get connector cleaner from Radio Shack.
Old Jul 19, 2004 | 09:44 AM
nat123's Avatar
nat123
tach issue
have checked the ground and seems solid, Also have cleaned the circuit board with eraser. could there be an issue with the tach signal via the wire. I was told that it has an inline resistor from the coil.. could this be bad?
Old Jul 19, 2004 | 10:37 AM
Oscar Meier
There is something about a black wire that needs to be grounded in the harness for the V8 that's not connected for the IL6.
Please try a search for "Tach" there are several threads on installation.
cyris426
30
Nov 23, 2014 06:25 PM
cyris426
Jan 17, 2014 07:27 AM
allerickb
Oct 15, 2009 07:36 AM
97rangerspl
1983 - 2012 Ranger & B-Series
Apr 11, 2003 03:52 PM
pcman
Feb 16, 2002 07:20 PM
