General Automotive Discussion
Block heater replacement?
Old Jul 18, 2004 | 07:02 PM
bgrckwlf's Avatar
bgrckwlf
I need to replace the block heater on my truck, started to leak, located just above my starter. I thought it should be easy but I am having trouble removing the previous block heater and I'm afraid of doing damage to the block. Any suggestions would help.
Old Jul 18, 2004 | 07:17 PM
fellro86's Avatar
fellro86
There is a strap of metal that flattens out when it was installed, you need to get it as loose as you can to get it out. Don't worry about the blk, unless you are chiseling on it, it will be ok. You could als punch a hole through the old heater and pry it out that way to. The strap behind will likely require pressure on it to ke from spinning, or as I just had said, poke a hole in it, you could block it that way.
maevans
Jan 1, 2009 11:56 AM
clay01
Nov 23, 2008 05:00 AM
viperrtblck
Dec 7, 2006 07:56 AM
automaticj5
2004 - 2008 F150
Nov 17, 2006 09:27 PM
BigBlue2
Sep 10, 2004 09:00 PM
