Engine Model and year
Old Jul 18, 2004 | 03:43 PM
davet18__'s Avatar
davet18__
Question Engine Model and year
I'm new to the forum and just purchased a 36 Ford Pickup that was partially restored. It will eventually become a street rod. Right now I'm going to get it running as is. I have the following engine that I need to identify:
Bell Housing Information: 20 Stamped into the housing
Unable to read raised casting Number Look like 2 V 7 or the V looks like a check mark.
Piston Bore: approx 3.106
Ford Pistons: Piston Size: Approx 3.075
Piston Markings: 01T F6 U5A 4 ring .040 stamped on top
Aluminum Dome Pistons
Cylinder Head Markings: 81T6049 AND 81T6050
Any idea of the year or is it stock with .040 overbore? Are there any other markings I should look for?
Dave T
Old Jul 20, 2004 | 12:04 PM
46fordtruck's Avatar
46fordtruck
I'll take a stab at this. 81T indicates the heads are about a '38, and the T is for trucks, so '38 truck heads(81 indicates first years the part was used). The pistons are stock Ford over the counter pistons, 01T would be '40 truck, and as you know, they are 40 over. Those are pistons you could buy from the parts dept when rebuilding your engine. So it's prob a late '30's block, that got rebuilt sometime in the '40's or '50's with a 40 over bore.
Old Jul 20, 2004 | 08:31 PM
davet18__'s Avatar
davet18__
I agreee i think that is about as close as I'm going to get on the exact year. The raised casting number looks like a 2 V 7 but that doesn't correspond with any casting number I'm been able to locate.
Thanks for the reply.
Dave T
Old Jul 20, 2004 | 08:47 PM
Carlene's Avatar
Carlene
Admom
Hi Dave and Welcome to FTE.
I can't help you with your casting number thing, but FTE does have a Flathead V8/V6 Forum that may have some answers for you. I did a search of that forum using the word "casting" and came up with quite a few threads. You may find your info there.
Good luck and let us know how things turn out.
SouthernCamper74
Feb 8, 2022 08:15 PM
Fellenz
23
Dec 8, 2014 04:51 PM
creator
Aug 6, 2013 05:16 PM
wrench jr.
Apr 2, 2009 10:01 AM
bryan_johnson
May 10, 2004 11:51 AM
