1. Oil bypass filter-this is a secondary filter that will get the majority of the small contaminants that the regular filter doesn't catch.
2. Coolant filter-filters out all the crud from the coolant system.
3. 4" exhaust-will help keep exhaust temps down when towing.
4. Ford AIS air intake-will allow you to maintain the warranty and it will filter better and flow more air keeping the engine cleaner and the exhaust temps lower.
5. Pyro, boost, and trans temp gauges-will help you monitor additional information above and beyond what the stock gauges do.
6. Run a fuel additive like Stanadyne Performance Formula in every tank. It will improve the cetane rating of the fuel and keep the engine cleaner. The improved fuel mileage usually offsets the cost of the additive. You can buy it HERE.
Do you or anyone know good places to buy items 1, 2, 4 and 5? Prices?
