Setting up a Preditor carb
Old Jul 17, 2004 | 02:25 PM
Texan1983's Avatar
Texan1983
i noticed when i was going to buy one that there are no vac. ports where do you put the things like your booster for the bakes and vac advance dist.? also i thought at one point they made and idle setup seperate and you had to buy one for street use if you wanted good idle. is this true?
Old Jul 17, 2004 | 05:53 PM
LxMan1's Avatar
LxMan1
It's been awhile since I have messed with one. I believe that they had a couple of different versions. A friend of mine had a pair on a blown big block Chevy in his 55 Chevy. I was constantly having to adjust them because they were so sensitive to temp changes. I wouldn't use one on a street vehicle. They work best on a pull truck that only worries about WOT.
Drac
21
Apr 20, 2013 07:40 PM
slomafarms
1997 - 2003 F150
Oct 21, 2011 07:17 PM
300/6 Freak
22
Apr 18, 2011 01:38 AM
Bobcat7
Jun 27, 2010 09:55 AM
SPL Tech
39
Mar 6, 2007 09:42 AM
