Sponsored by: Auxito
01 digital dispay problem
Old Jul 17, 2004 | 11:42 AM
Silverwinger's Avatar
Silverwinger
My daughter has an '01 F-150 that has a problem with the digital display portion of her dash (odometer,radio display, overhead temp and compass) go blank when the headlights are turned on, she was told that it was her headlight switch, she purchased a new one and I just changed it for her and no improvement. Suspect it must be a module or relay but what and where?
Old Jul 17, 2004 | 06:07 PM
LxMan1's Avatar
LxMan1
Welcome to the forum
This may be a stupid question, but is the dimmer switch turned all of the way down?
I would also check all of the fuses.
Do the regular dash lights work?
Old Jul 17, 2004 | 06:52 PM
Silverwinger
Not Stupid!, the dimmer switch works fine, all regular lights work ok, just the "digital" display items worlk fine with the headlights off, no work when on, fuses all metered out as good. Thanks for the reply.
Tom
Old Jul 24, 2004 | 08:35 AM
Rajeeb_Das's Avatar
Rajeeb_Das
Having similar problems
If you find the solution to this problem. Please do post it. My odometer doesn't turn on when car is first started. Then after a little time with a right bump, it activates. Odometer is keeping milage fine, just an issue with the display. Don't want to pay $450 to replace it.
Regards,
Rajeeb
Old Jul 24, 2004 | 12:12 PM
HomerWinzlow's Avatar
HomerWinzlow
Rajeeb see this thread for a fix for your odometer..
https://www.ford-trucks.com/forums/s...d.php?t=196821
Old Jul 24, 2004 | 12:16 PM
HomerWinzlow
Silverwinger, check fuse 18, a five amp fuse in the under dash fuse box.
Old Jul 24, 2004 | 03:26 PM
Rajeeb_Das's Avatar
Rajeeb_Das
Thank you so much. I knew it was something simple!!!! Have a great afternoon.
Regards,Rajeeb
chayes01
15
May 13, 2010 05:30 PM
Ed
Aerostar
Dec 18, 2007 08:58 AM
Ed
Aerostar
Oct 31, 2007 12:13 PM
TallPaul
Sep 28, 2004 07:19 AM
dcexplorer
Oct 9, 2002 03:27 PM
