Overheating problem
Old Jun 8, 2002 | 04:11 PM
OneShotBandit's Avatar
OneShotBandit
Overheating problem
Wazz up guys (& gals), My problem is that I had the AC on for the
first time this year & my temp ga. went up & check engine light came on, it did this w/the heater on also. Is this the classic thermostat faliure? The antifreeze was spraying out w/the engine still running.
I know this question may seem stupid to ya'all, but my last truck was a '83 Chevy & was a lot simpler to work on (no AC, SOHC, etc.). I was
thinking maybe the waterpump, but haven't notice any pinging or any
other noise. This problem was sudden., Thanks for any info.
Old Jun 8, 2002 | 06:12 PM
Dialtone's Avatar
Dialtone
Overheating problem
Thermostat would be my first item to check and most likely fix. Waterpumps generally are no problem unless shaft seal is leaking. If it was, you would have fluid dripping from neck of the pump weep hole.
Thermostat is most likely 195 degree. You can take a candy thermometer (if your wife will let you borrow it) and check the water temp in radiator. If temp guage is thru the roof and water temp is much cooler, replace the thermostat. Not too tough, just got to hold your mouth right at times.
Dialtone.
Old Jun 9, 2002 | 11:46 AM
OneShotBandit
Overheating problem
Thanks dialtone, I kinda was hoping that was the problem (hopefully),
but I just keep reading these "horror" stories about repairs. I've had
my '98 for just about a year (bought off the original owner) & have
spent $2100 already. This was a "company car", the owner was an Insurance adjuster. My SUV only has 55,000 mi,'s and I still have that
damn grinding noise from the driver's side front wheel that NO ONE can
seem to find. Mechanic said to keep driving it & see if it breaks or
get's worse, Ford mechanic say's it's the transfer case!
Old Jun 11, 2002 | 08:52 AM
OneShotBandit
Overheating problem
Dialtone, it was the thermostat($30.00!). "We" did figure that was the
problem, but w/all the complex components in these vehicles ya gotta
be an Engineer to work on 'em. I sure wished I hadn't sold that '83
Chevy truck!
Old Jun 11, 2002 | 03:01 PM
4x4_EB_Explorer's Avatar
4x4_EB_Explorer
Overheating problem
Super Duty Daddy
Electrical Systems/Wiring
Oct 7, 2013 08:27 PM
Revmitchell
18
Jul 19, 2012 02:35 PM
maverick1701
Jul 14, 2009 07:59 PM
biggieou
18
May 22, 2004 10:40 AM
