A/C on - Volts drop,engine vibrates
Old Jul 15, 2004 | 10:41 PM
dr76's Avatar
dr76
For the past few days, when I turn on the A/C, I notice the Volt gauge drop (to the "N" or "O" in "NORMAL", when it's usually on the "M") and engine starts to stumble/vibrate (loss of RPM), but when I take out of gear and give it some throttle everything is OK.
This also can happen when coming to a stop when the A/C is on, but not always.
I've thoroughly tested the alternator and it's checking out great...14.7V @ the Bat with hi-beams on and blower fan on high. All tests of the regulator were also well within specs. Battery is pretty new and all wiring/grounds look fine.
Does this have anything to do with the A/C "cycle switch" (not sure of the name) that's part of the dryer? Does this inform the PCM that the a/c is on (clutch engaged) and to supply more fuel to compensate for compressor drag?
Any other ideas?
This is for a '93 Ranger, 2.3L, manual tranny.
Thanks!
Old Jul 15, 2004 | 11:02 PM
Rockledge's Avatar
Rockledge
Did you test the alternator when A/C compressor was running?
The PCM is indeed programmed to raise idle speed in order to account for the additional load that the A/C puts on the engine. I believe the cycling switch is the input for this. But this adjustment (allowing a little bit more air and fuel in) happens only during idle and deceleration (i.e., closed throttle), not at part throttle. The PCM is also programmed to cut off the A/C compressor at WOT.
Old Jul 16, 2004 | 12:06 AM
BrotherD's Avatar
BrotherD
I'd check to make sure the belt is not slipping. If the belt is worn or the tensioner is weak. Could cause the belt to slip.
Old Jul 16, 2004 | 05:08 PM
dr76's Avatar
dr76
Yeah, I did also check w/ a/c on, but had to "goose" the throttle a few times before it would hold a steady idle. I don't recall exactly, but know the Voltage was still above 14. And I should have stated in my original post that this only happens when I turn the a/c on at idle (at a stop light or before leaving home) and then when idling down to a stop when a/c on, so it probably is this "cycle switch".
I'll double check the belt as well...
Thanks for the replies
