ac always engages
Old Jun 17, 2002 | 05:10 PM
dave05065's Avatar
dave05065
ac always engages
i have a 94 explorer sport and when i have my motor running the compresser seems to be running and the clutch engages even when i dont have the ac on
Old Jun 18, 2002 | 08:32 AM
propellerhead's Avatar
propellerhead
ac always engages
I ask the Ford dealership that same question.
If you have it set to defrost mode, or defrost and feet mode, the compressor will kick in to dry the air.
Old Jun 18, 2002 | 01:40 PM
Jharger's Avatar
Jharger
ac always engages
Because the compressor shaft seals will dry out and leak freon if not used regulary (the lubricating oil is in the freon and needs to circulate to keep the seals wet), some manufactures implemented a control circuit that kicks on the AC compressor when the defrost, front or rear electric, is on. This extends compressor life, saves freon and protects the environment. I'm sure the EPA has place this requirement. However, my 93 X doesn't have this feature and I'd be surprised if your '94 does.
Old Jun 18, 2002 | 06:02 PM
Rubacha's Avatar
Rubacha
Post ac always engages
