gear change
Old Jul 15, 2004 | 03:03 PM
1984F15016's Avatar
1984F15016
gear change
how easy is it to do a gear change in a rear end for a weekend mechanic? I know about back lash, and spacing, but not enough to do it. is there a book that teaches how to do it right, or is it worth it to have a pro do it, and how much can that cost?
Old Jul 16, 2004 | 08:25 PM
Tranzmaan's Avatar
Tranzmaan
rear gears
This is definitely a job that you want right the first time. I would recommend getting help from someone that has done a lot of rears. It is usually problem free, but if you have to start changing shims on pinion depth or end up with a funny gear pattern it can turn into a hassle. Generally you put the shims back were they came from and every thing will fall back into place. "BUT" if it doesn't thats when you have to change shims around according to how your gear pattern comes out. You also need access to a press to press bearing on and off. Once someone shows you how one time it is really pretty easy.
Old Jul 16, 2004 | 09:04 PM
cpettymore7777's Avatar
cpettymore7777
9" rear is the easist to work on and there are books that show step by step with pictures
Old Jul 17, 2004 | 09:28 PM
1984F15016's Avatar
1984F15016
why is 9" easier?
