vacum pump squeel
Old Jul 15, 2004 | 01:24 PM
shendoa's Avatar
shendoa
vacum pump squeel
well I fixed my squealing vacum pump. i took the pump off then removed the pully, then removed the clip next to bearing. I did not take the bearing out, then i took a small wire and pried the plastic cap that seals the bearing, bearing carefull so i would not damage it. packed the bearing with high temp gerase, put back together, no more squeel, hope it last?? [FONT=Arial Black]
