Wheel Hop
Old Jul 15, 2004 | 11:06 AM
Charcoal_6.0's Avatar
Charcoal_6.0
Wheel Hop
Does anyone else have terrible wheel hop or is this just a 6-speed thing? Or it could be just a reg. cab long bed thing. Is there a cure?
Old Jul 15, 2004 | 11:47 AM
kw5413's Avatar
kw5413
Auto, SC, Longbed, FX4...no hop. Goes fast.
Maybe the camper pkg helps mine. Dunno.
My '02 F-150 FX4 SC long bed had wheel hop pretty bad. No camper pkg.
Old Jul 15, 2004 | 01:30 PM
va_redneck's Avatar
va_redneck
Reg cab and long bed make for a light backend. Too much to push without a lot of wieght on the back end. a camper pkg would help reduce spring wrap.
only options I think might help would be trac bars or stiffer springs. Or you could upgrade to a crewcab
Old Jul 15, 2004 | 01:58 PM
Charcoal_6.0
Are trac bars easy to take on and off? (Trips to the dealer)
Old Jul 15, 2004 | 02:35 PM
va_redneck's Avatar
va_redneck
It depends on the type you buy. I have never heard of a trac bar voiding a warranty. Although it depends on your dealer. I have always put chips in my trucks and lift kits. never a warranty issue until my service writer quit. New guy ****ed me off and I had to diagnose the problems for him. Then he charged me and called me a liar...
Well back to the question... depending on the type you get you can disconnect 4 bolts and be done with most if you had to. But it would be hard for a dealer to argue that it would void a warranty.
Old Jul 15, 2004 | 03:58 PM
04F250CC60's Avatar
04F250CC60
I'm building my own traction bars. I have a CC auto shortbed fx4. I measured my friends SC longbed 6 speed 2x4 and it's only an inch longer from end of transmission to pinion. His and mine both have real bad wheel hop/axle wrap in the dirt.
Old Jul 15, 2004 | 06:42 PM
Crownie's Avatar
Crownie
Unhappy
I have noticed a bit of this (more than I expected) when on a sand/gravel road and accelerating from a stop. FYI CC 4x4 Regular bed with Ltd slip.
Old Jul 16, 2004 | 05:55 AM
Charcoal_6.0
I'm not worried about the trac bars voiding the warranty, but I would say the dealer would be slightly tipped off of a tuner or module if they saw trac bars under a truck. I would think that would be worse than guages.
Old Jul 16, 2004 | 07:46 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
**** is against the rules. It is considered "masking" profanity with symbols
I if you type foul or vulgar language it bounces the filters and places **** so either way..........do not do it.
I appreciate your support to keep this a Family site
Old Jul 16, 2004 | 08:40 AM
va_redneck's Avatar
va_redneck
Tim,
I appologize. I did not think in the context that it was vulgar. However, I understand that we are setting high values here and I will make every effort to avoid filters in the future. I appreciate your efforts to keep this a family site and support you completely. I hope no one assumes that I used a different word than I did as the other options would make my mother think she raise a sailor
Old Jul 16, 2004 | 11:13 AM
IB Tim's Avatar
IB Tim
Tim,
I thank you for you honesty and true support for a GREAT site.
Be cool
