Buying used supertuner???
Old Jul 15, 2004 | 07:47 AM
mizter1's Avatar
mizter1
Off my buddy (1705). Does anything have to be done to it for it to work on my truck?
Thanks,
Troy
Old Jul 15, 2004 | 08:46 AM
TXstroker01's Avatar
TXstroker01
Your buddy has to return his truck to the stock programming using the tuner first, else the tuner will be "VIN Locked" and useless.
Nothing else has to be done to the tuner before using it (assuming you have a 94-03 7.3L PSD). If you haven't already, it's not a bad idea to open up the exhaust (i.e. 4" turbo back) to keep the EGTs down, and gauges for monitoring (EGT, boost, trans temp). While you're at it, you might as well go with an open element intake (i.e. Tymar).
I would find out what Revision of software is on the tuner, too. The new ones are a "Tri-Tune" programmer, meaning they have 3 programs (70/90/110). I believe some of the older ones only have 2 programs (60/85??). Just make sure you know what you're buying.
Hope this helps.
Brent
swirk
May 2, 2002 08:01 PM
Ken00
1983 - 2012 Ranger & B-Series
Feb 4, 2002 10:38 PM
skud
Dec 30, 2001 11:22 PM
fatdaddy
Dec 24, 2001 06:19 AM
