I have a 1998 Ranger 3.0. The airbag light has come on and it is flashing a code of 25. Does anyone have a list of codes for the airbags or know what this code is.
Yes, I turned off the passenger side airbag, then turned the car on and off a couple of times and the problem still exists with the passenger airbag on or off.
Hi Pete!
I got this code on my 98 4.0 and it drove me nuts. I finally unplugged and disassembled the little plastic module where you disable the passengers airbag. The lightbulb was burned out! I bought a new one at Radio Shack for $1.68 and soldered it onto the circuit board.
The tip is: When you start the truck, the little yellow light next to the disable keyswitch should come on for a few seconds. If it doesn't, YOU FOUND IT!
