360 question
Old Jul 14, 2004 | 01:17 PM
thomadm's Avatar
thomadm
Lightbulb 360 question
I was just wondering if my 360 in my 1986 Jeep Grand Wagoneer is a FE 360? It has ford stuff on it(distributor, motorcraft 2150 carb), but is it really the same motor? This is one of my issues with Jeep of that time, because they were made by AMC back then.
Old Jul 14, 2004 | 01:21 PM
led sled's Avatar
led sled
no the 360 in your jeep should be a chrysler engine. the only way it could be a FE is that if someone switch motors. the chrysler 360 and ford 360 are two totally different animals. the chrysler 360 is a small block and the ford 360 is a big block
Old Jul 15, 2004 | 03:03 PM
79Indy's Avatar
79Indy
The 360 in the Jeep Grand Wagoneers is an AMC V-8 and is from the 277-304-343-360-390-401 family of AMC engines. It shares nothing with the Ford FE engines or the LA series Chrysler engines.
Old Jul 15, 2004 | 03:09 PM
led sled's Avatar
led sled
i was thinking about the newer jeeps, the grand cherokee's !!! talk about a brain fart.
Old Jul 15, 2004 | 03:11 PM
79Indy's Avatar
79Indy
Most Grand Wagoneer owner wish they had one of those engines!
Old Jul 15, 2004 | 03:43 PM
thomadm's Avatar
thomadm
thanks guys, just wanted to check. This thing is a nightmare. Cant get it to run, spits back through the carb. I replaced timing chain and just about everything else, so im out of ideas. Was hoping i could find help here if it was a FE motor.
Old Jul 15, 2004 | 03:46 PM
79Indy's Avatar
79Indy
Help with your Jeep can be found on the forums at ifsja.org. It's a very good and helpful board.
Old Jul 16, 2004 | 04:10 PM
scroob's Avatar
scroob
Check to see if your distributor is 180 degress out. It's a common mistake and applies to almost all engines.
akguy09
Nov 21, 2014 12:35 AM
1997f1504X4,4.6L
Oct 4, 2010 03:45 AM
Trios69
Mar 26, 2007 09:08 PM
oldhalftons
General Automotive Discussion
Sep 5, 2004 08:40 PM
safer
18
Feb 23, 2001 11:17 AM
