rebuild
Old Jul 14, 2004 | 12:12 AM
tankbuster71ford's Avatar
tankbuster71ford
Trailering
rebuild
anny body rebuild their 360? how much did it cost u?
Old Jul 14, 2004 | 09:09 AM
76supercab2's Avatar
76supercab2
From reading the posts about people's rebuilds I'd say $3000 is a good ballpark for a basic rebuild including some machine work. 'Course you could spend less or more. I'd probably try to have $4000 on hand for any overrunns.
Old Jul 14, 2004 | 09:23 AM
led sled's Avatar
led sled
it is almost cheaper to buy a remanufactured motor, and you would have a warrenty with it .
Old Jul 15, 2004 | 02:40 PM
FORD352V8's Avatar
FORD352V8
$3000 to $4000 is a bit high I think. For my 352 HIPO rebuild it cost me only $1600. This included crane cams powermax 343901, Edlel RPM peformer, edel carb, headers. havent dyoned it yet but I have raced with it and wow what a difference from stock. I personally prefer higher revving small FE's to the larger ones they seem to do better in racing. I havent lost a street race yet. I havent took it to the track yet so dont have any numbers. Tire wear is starting to become an issue. I burn out in every gear except 4th where I can chirp the tires. I still cant get used to the power I have now. I got a warning from a cop for "accerlating way too dangerously" but that hasant stopped me.=)
Old Jul 15, 2004 | 03:03 PM
led sled's Avatar
led sled
i have a 390 well i have quite a bit in it. it really depends on what you want. for a mild hop up it wouldn't be to bad 1000 or so, but a higher performance build, such as mine, edelbrock heads, forged pistons, adjustable valve train, nos, etc would be lot more expensive. it basically boils down to what i said earlier what you want tfrom your engine. i can run high 7's in the eighth mile, thats in a 74 F-100.
Old Jul 15, 2004 | 03:47 PM
FORD352V8's Avatar
FORD352V8
Ah its a bit more then a mild hop dude. I think I have at least 100 more HP and maybe 80 or 90 more ft lbs. My price included head work as well.
Old Jul 15, 2004 | 03:51 PM
led sled's Avatar
led sled
i wasn't meaning yours was a mild hop up, just was saying a mild hop up is aroung 1000 or so and more you get into it the more it cost.
Old Jul 15, 2004 | 04:14 PM
Randyb12's Avatar
Randyb12
Parts:
Edelbrock 750cfm carb. 239.00
Edel Perf RPM intake 289.00
Edel heads 1232.00
Edel Perf RPM cam 158.00
SpeedPro Forged pistons, rings and Clivite bearings 524.00
Melling HV oil pump 58.63
Carter 120GPH mech fuel pump 59.00
Hedman headers 139.00
MSD 6AL ignition 200.00
MSD timing advance computer 109.00
MSD 8.5mm Superconductor wires 70.00
MSD capadapt HEI cap for DuraSpark dist 29.00
Holley Phasing kit for DuraSpark dist 16.00
Machine shop:
recondition the crank and rods
Balance the entire rotating assembly
bore, hone and deck the block
assemble the short block.
Total: 736.00
Dress up:
Edel Chrome valve covers and Air cleaner, Lots of SS braided lines 200.00-300.00
This is what I spent to get 418HP and 430TQ while looking pretty too.
Old Jul 15, 2004 | 04:38 PM
EgoMan's Avatar
EgoMan
1500 is a fair round about estimate........If you do it your self...not for performance but to just recondition and maybe put a small cam. For 3000 thats like stage one for performance you can get alot out of 3000 dollars.
Old Aug 10, 2004 | 05:58 PM
eriksf250's Avatar
eriksf250
Talking
what kind of truck do you have and can you give me the info on the stuff you did to your engine and what kind of gears you have in the rear. I wouldn't mind my truck doing that, especially a 352!
