Sponsored by: Kumho
Steering is loose
Old Jul 13, 2004 | 09:28 PM
Peach's Avatar
Peach
Steering is loose
My trucks steering is loose, has been since I got it..It takes my full concentration to keep it in a straight line. Any ideas?
Old Jul 14, 2004 | 12:15 AM
fordmudrunner2020's Avatar
fordmudrunner2020
Check your tie rod ends and your steering shaft for play if you find any anywhere then thats your problem if not maybe your steering box may need some adjustment or replacment.
Old Jul 14, 2004 | 09:49 AM
73Custom's Avatar
73Custom
Have someone turn the wheel while you look over every joint from the column to the wheels. Pay special attention to each of the tie rod ends. Or take it to a shop for an estimate - they will look it over and tell you what it needs...
Marty
Old Jul 14, 2004 | 12:38 PM
95-F-350-4x4's Avatar
95-F-350-4x4
ford trucks are notorious for loose steering.
Old Sep 14, 2004 | 11:24 AM
JerichoM1070's Avatar
JerichoM1070
How do you adjust the play in the steering box? Is it just a matter of turning the adjustment **** until it feels right?
Old Sep 14, 2004 | 01:37 PM
gatesj's Avatar
gatesj
You have to be very careful adjusting that, if you get it too tight you will blow it very quickly. Check everything else first and make sure it's tight, the steering box adjustment is a last resort. The haynes has a procedure, it involves pulling the pitman arm and using an inch-pound torque wrench to figure out how much resistance there is at the top of the steering column. Don't mess with that adjustment without knowing exactly what you're doing, you'll screw up the box.
Old Sep 15, 2004 | 05:06 AM
Patrick_PDX's Avatar
Patrick_PDX
Adjusting you steering box isn't rocket science. Just loosen the locknut and turn the screw in with a screwdriver.....and as your GENTLY turning the screw....... have someone wiggle the steering wheel back and forth. When it gets to the point you can no longer GENTLY turn the screw- STOP, and back it up a full turn and tighten the lock nut.
If you overtighten it......... the steering wheel will "not return to center" after making a turn while driving. So DO be carefull when test driving after you make the adjustment.
Old Sep 15, 2004 | 11:28 AM
jtmerritt's Avatar
jtmerritt
Follow gatesj's advice and only do this with a inch pound torque wrench and to spec for your truck. On my 99 it is 13 inch pounds over center. Adjusting any other way may work OK but you may be overloading the gearbox bearings and not even know you are doing it. Ask me how I know this?
John
Old Sep 20, 2004 | 10:44 PM
JerichoM1070
Too late.
Thanks for the information guys. Unfortunatly, I didn't get the info until I was back in Iraq. I'll have to give it a shot when I get home.
Old Sep 25, 2004 | 05:18 AM
missouguy's Avatar
missouguy
Good luck to you, and THANKS.
Frank
Old Nov 23, 2004 | 01:09 AM
boomvader's Avatar
boomvader
Frank
Amen Brother. I second that to all of you serving our country!
Old Nov 23, 2004 | 03:19 PM
JerichoM1070
Missouguy, boomvader - Fallujah is a tough place and everyone appreciates the support that we get from back home.
Thanks.
